Don’t think this is a biggie, as the browser is working, that said I don’t like error messages
I installed brave-bin from the aur using Yay. Last night it found an update. I’m writing this in Brave so clearly it works, but the error message seems to indicate it cannot find a library? I believe it’s a symlink that wasn’t created, is this correct?
I don’t know if the error is from Brave or from my window manager? The message is in my ~/.Xsession
Full error message reads thus:
[870:870:0829/093212.581635:ERROR:gl_implementation.cc(281)] Failed to load /usr/lib/brave-
bin/swiftshader/libGLESv2.so: /usr/lib/brave-bin/swiftshader/libGLESv2.so: cannot open shared
object file: No such file or directory
[870:870:0829/093212.585020:ERROR:viz_main_impl.cc(170)] Exiting GPU process due to errors
during initialization
[892:892:0829/093212.679321:ERROR:gl_implementation.cc(281)] Failed to load /usr/lib/brave-
[892:892:0829/093212.681404:ERROR:viz_main_impl.cc(170)] Exiting GPU process due to errors
[921:921:0829/093212.975435:ERROR:gpu_channel_manager.cc(398)]
ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[846:863:0829/093212.975920:ERROR:rewards_service_impl.cc(194)] Failed to read file:
/home/<username>/.config/BraveSoftware/Brave-Browser/Default/ledger_state
System as follows, let me know if more needed:
5.2.9-arch1-1-ARCH
$ brave --version
Brave Browser 76.0.68.132 unknown
Amateur but honest
Telegram, Cryptocurrency, The sites that pay
