window.outerWidth and window.outerHeight are incorrect and they are changing with zoom. They should remain constant if the window size doesn’t change.
Reproducing it by opening devtools console for any live website:
window.addEventListener('resize', function() {
console.clear();
console.log("Inner Width: " + window.innerWidth + " Outer Width: " + window.outerWidth);
…and then zooming in/out → the outerWidth is changing together with the innerWidth, but only the innerWidth should change.
Any external live website.
No problem for localhost, file URLs and data URLs
yes (Block fingerprinting: ON)
yes
Version 1.70.119 Chromium: 129.0.6668.70 (Official Build) (64-bit)
I tried version 1.68 on browserling.com, it works properly even with strict fingerprinting setting.
