NOTE: Any “one-liner” or topics requesting support or reporting bugs that do not make an effort to include as much of this information as possible will be closed immediately. Repeatedly posting as such is grounds for banning._
Thank you!
Description of the issue
Exact URL of the website in question
Did the issue present with default Shields settings? [Default states are: Block: Ads/Trackers, 3rd Party Cookies, 3rd Party Fingerprinting Allow: Encrypt Connections enabled (HTTPS), Scripts] (yes/no)
Does the site function as expected when Shields are turned off? (yes/no)
Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration. (yes/no)
Does the site function as expected when using Chrome? (yes/no)
What Operating System and Brave version/Build are you using when you encounter the issue?(See the About Brave page in the main menu)
