Why is Brave ads keep popping up
Ads keep popping up a bunch at a time and it’s getting annoying
  1. Figure out why its doing it
  2. Is the code missed up
  3. Needs fixed
Mobile Device details
Because you have Brave Rewards turned on?
Then turn it off? Or adjust the amount of ads that can appear per hour?
If you’re referencing any other issue, you gave us nothing to be able to help. Poor description, no details on which version of Brave or your Android you’re using, or anything.
What more do you need? The browse keeps openings websites without me doing it. Do you need to know what phone I have? Let me know and I will tell you what I can.
@MissLady Well, first thing is I was going by your phrasing. So you had mentioned that Brave Ads keep popping up. Brave ads would be the push notifications that occur on your phone or the occasional background images/sponsored image on your New Tab Page. If these are the ads you’re talking about, you can click on the Rewards triangle and turn off Rewards. Then it won’t show notifications anymore. Or you can go to brave://rewards → settings icon → change Notification ad frequency.
When you say that the browser keeps opening websites without you doing it, that wouldn’t be Brave Ads. Can you try to better describe what is happening and when? For example, is your browser opening by itself? Or are you just seeing new tabs/windows open as you’re visiting sites? If it’s the latter, then it just seems to be pop-ups or something, which may be part of the websites you’re visiting.
And yes, what would be helpful to know would be:
  • What version of Brave are you using?
  • Which version of Android?
  • Can you share a screenshot of what you’re seeing?
  • Does this happen while you’re on any particular website?
  • Do you have Shields enabled?
  • What Shields settings are you using? (Settings → Shields)
  • Do you have any content filters active? (type in brave://adblock and look. If not active, might want to turn on Fanboy Annoyances and uBlock Annoyances)
Hope that helps I screenshot them. Also I use Virtual shield. When I go into the browser websites just pop up.
