Please provide the following basic troubleshooting information, which is needed to help diagnose your issue:
Briefly describe your issue:
Are you using a VPN? (yes/no)
Have you manually turned OFF Auto-contribute on all of your devices linked to Uphold??
Does your device pass Safetynet? You can test here: https://play.google.com/store/apps/details?id=org.freeandroidtools.safetynettest&hl=en_US&gl=US.
Yes I have checked
It’s passed @steeven
Hello1
We use track and drop, it will direct you which icon object to drop your triangle or circle or a squire, this is the way a system calculate your monthly work!
Not understand anything its on mobile that method is for desktop
I m facing the issue in android phone
@Vitalis That doesn’t apply to mobile devices.
Ok , in this case ,I would advice you to consult Mobile Support directly.
