Whitelisting shield settings for sites
Hi Support,
I like browsing with the shields on aggressive blocking mode.
Is their an option to whitelist websites that you frequent often so Brave will lower the shields to the custom security level you set, for that site?
That would be awesome if the features their.
At the moment, It seems I can only manually change the shields or disable them EACH time I visit a site. Surely, there’s a way for brave to remember your settings for each site?
Thanks,
Stardust
@stardust,
If you change the Shields settings in the Shields panel (lion icon in the address bar) while on the site, the setting will be remembered. Shields settings configured in the panel are site specific, whereas Default Shields settings (Menu --> Settings --> Shields) are applied globally. More on Shields here:
ah, how did I miss that!
Thanks, it is obvious now.
