Hi. I clicked on “claim rewards” earlier this month (July) for my June BATs. Where did they go? I do not have enough funds for an Uphold wallet. Did they go somewhere else? I can’t see where those June rewards are stored. Thanks.
Mac OS.
Version 1.27.109 Chromium: 92.0.4515.115 (Official Build) (x86_64)
Not on Uphold, no.
No, this was my first time trying.
Are you using a VPN? (yes/no)
No
Yes
Does not apply
On your brave://rewards page you should see a box in the upper right (I assume it’s the same on Mac as on Windows and Linux) that has a blue/purple background with X.XXX BAT in large characters (where X.XXX is a number). What is that number? Below that it should say “Rewards Summary July 2021”. Can you post a screen shot of that quadrant of your screen?
When you clicked the “claim rewards” button, did you see a triangle that you had to drag to another shape? Was it successful?
Hi there and thanks for the help. I honestly don’t recall whether or not I had to do the “drag the triangle” step on this computer. Interestingly enough, I have another computer upstairs, and just a few minutes ago I claimed my unclaimed rewards on that computer, did the “drag the triangle” step, and my rewards successfully populated into my local wallet. That doesn’t seem to be the case on the computer I’m having the issue on. Here’s a screenshot of my rewards screen:
You appear to have Auto Contribute enabled according to those screenshots. Be sure to check your Contributions tab on brave://rewards-internals. You may be tipping/contributing without realizing it.
Aha…I think that might’ve been it. Looks like I contributed .75 BAT to a couple sites back on July 11th. Guess that explains part of it. Thought I had more BAT available to claim but perhaps not.
Not that I’m opposed to contributing and tipping, but I’d prefer it to be voluntary lol. Thanks for the heads up! I’ve disabled the auto-contribute feature, so it’ll be interesting to see what happens when my next claim opportunity comes around.
