When tabs get close to the minimize, maximize close button. I click on the white space between and it either auto loads a new tap or it registers minimize instead of white space click. This has been an issue for since a couple updates ago. Any chance a fix could be done for this? Thank you. When you have enough tabs open and it gets close to the buttons it does not register the white space between the buttons. This started two updates ago and isn’t getting fixed any time soon. Thank you. It’s just a minor frustration challenge.
While there’s no template, I tried to reproduce based on filling my tab bar with tabs until it spanned the bar up against the window controls, however clicking on empty space isn’t doing what you’re stating. (I’m in dark mode, so to me it’s dark gray, unless there’s something else visible to you?)
If you don’t mind, can you attach a screenshot of the area you’re referring to? Also, at the minimum what version of Windows and the current version of Brave you have installed? (I know you stated previous versions but want to check on the current build to ensure we match since I can’t replicate, or might not be replicating it correctly per your instructions).
