I tried to look it up on the forums as well as reddit posts and the most I found was that it’s an script injection extension like tampermonkey or greasemonkey, and not much else. Could not find anything about whether or not deleting it is safe. So, can I?
Also, why does it have thousands of files inside of it, that too in different languages.
See this: What does "greaselion" do and how does it work?
Brave is supposed to delete those files automatically on exit, but they will be left behind if there’s a crash.
If Brave is closed OK to delete.
it’s ok to delete all of them?
@ArcRe3,
Are you referring to the temp files that you find in?
C:users\[your user name]\AppData\Local\Brave Software\Brave-Browser\User Data\
If so, yes those files are perfectly fine to be deleted.
