NOTE: Any “one-liner” or topics requesting support or reporting bugs that do not make an effort to include as much of this information as possible will not be responded to. Repeatedly posting as such is grounds for banning._
I just learned of the Brave browser and it may be exactly what I was looking for. I just need to know the answers to the following questions to figure out when to use it.
- Is Brave color managed?
- Does it color manage a second display as well as the first one?
- Does it reference the monitor profile with either sRGB or Adobe RGB?
- What does it do to display images without an embedded profile?
- Will it show Adobe RGB correctly on a wide-gamut monitor?
I’m not looking for a right or wrong answer. I just want to understand the capabilities to decide how I might use it. I look forward to your response and appreciate your time.
N/A
Brave 1.18.78 Chromium 87.0.4280.141 (Official Build) (64-bit)
Windows 10 Ver. 2004
N/A
