Websites settings are not saved anymore
For a few days now, Brave has started to no longer save site settings, so I find myself with Whatsapp that doesn’t keep the background set, Twitch that doesn’t keep the playback speed, YouTube that doesn’t keep the player configuration, etc… The problem is general and widespread, it doesn’t seem to depend on specific sites. And it is HUGELY annoying.
Searching the reports already present, I found one from 2021 (now closed, otherwise I would have commented on that, which would have been much more convenient and effective) which cited some changes to localStorage management as the cause of the problem. (see → Settings for some websites not saving with this version of Brave)
There are no specific steps to reproduce the problem, it is widespread through all sites, just try some of the ones I mentioned above to verify the issue.
Brave Version:
1.52.119 Chromium: 114.0.5735.90 (Official Build) (64 bit)
Windows Version:
Windows 10 Pro Version 22H2 (Build 19045.2965)
Until some days ago everything was fine.
I have the exactly same issue.
