Website subdomain with dashes shows as not secure, when the same shows as a secure connection on Chrome
Created a new subdomain with dashes and then got a free Cert from SSLForFree.com and applied the Cert. So the right Cert shows on Brave and as Valid, but Brave still shows “Not Secure” beside the address. But when I opened the same pages on Google Chrome, it shows that the Connection is Secure.
2020-11-04 12_06_19-ListMessenger Light 2.2.1 Setup - Brave
2020-11-04 12_09_31-
2020-11-04 12_08_19-
  1. Create a subdomain with dashes.
  2. Obtain a Cert for your new subdomain from SSLForFree.com
  3. Apply the Cert to the Subdomain.
Should show that the connection is secure, like it does on my main website.
2020-11-04 12_14_23-
Version 1.16.72 Chromium: 86.0.4240.183 (Official Build) (64-bit)
Thank you.
Showing as secure here, not sure if showing the cert is instant. Creating a new sub/domain may not update the ssl certs straight away. But it’s looking good
@life777eternal
Ok, I see that now too, I just updated Brave after I posted this. Maybe the update fixed that, it was showing as not secure before.
Thank you.
2020-11-04 13_59_30-Test - Brave
