Weather.com refusing to load weather
Weather.com refuses to load weather for a given location after using it for the second time. Each time I clear the cookies, it works the first time, then refuses to load any time after the first time.
  1. Open Brave Browser
  2. Search weather.com
  3. Type in a location
  4. If it works refresh the web page
  5. Type in a location again
Displays the weather details for a given location.
1.80.113
** Desktop Device details**
Windows 11 Home version: 10.0.26100 build 26100
Mobile Device details
Android 15
One UI version 7.0
The issue occurs on both desktop and mobile devices.
@Skyler0x
Tested on iPhone 14, iOS 18.5, Brave Browser (iOS) v1.79 (124). Global Brave Shields allowing cookies and Javascript; otherwise Brave Shields UP. Using Private Browsing Only.
No problem.
@Skyler0x not seeing any issues with the site on Android in Brave but I am seeing a different issue on Windows. Looks like after the first attempt (which is successful), I’m unable to select the search field again to enter another location.
When I disable Shields, the site works as expected. Will loop a team member in to take a look at this.
Loading here; Under a VPN it’ll show the USA location, if I allow the location it’ll show the NZ results.
Fixed the top empty space issue on weather.com also.
