Washington post
The Washington Post has stopped being visible in Brave. Nothing has changed in my configuration. Brave displays a Washington Post page for about 3 seconds and then Brave shuts down completely.
Hi, @dkantor606. Could you type brave://version in your address bar, hit return/enter, and copy/paste the Brave version and OS details from the resulting window? In my case, I have no trouble browsing the Washington Post website with default Shields settings in Brave 0.73.26 Chromium: 78.0.3904.70 (Official Build) nightly (64-bit) on macOS Version 10.14.6 (Build 18G95), both logged in and not. The version info was taken from this (and should look basically the same regardless of Brave version and OS):
Yeah I saw it, just investigating it.
Visiting this site will cause the browser to crash;
https://www.washingtonpost.com/arts-entertainment/2019/10/27/snl-brings-back-alec-baldwin-take-trump-supporters/
This js script is causing it I believe;https://www.washingtonpost.com/notification-sw.js
@dkantor606 Just want to confirm, can you test Brave beta (with sheilds on), does Washington Post crash in Brave beta? I’m only seeing a crash on the release build on my setup.
Thanks–will check it out.
@dkantor606 what extensions do you have installed?
I don’t have any extensions installed at all.
In my case, the crash was caused by a paywall extension. which I’ve disabled. I would try clearing the cookies/cache first since its paywall can be hit quickly.
The problem does not exist in the current beta version.
