I really like the Brave browser, but today I can’t sign my wallet, because the wallet sign doesn’t appear and can’t be clicked.
I have tried various methods such as deleting cache, deleting data, reinstalling, connecting wallet still works but wallet sign popup still doesn’t work. please fix it
@Bahti4r0 It would really help if you could provide more details. For example, we need to know:
- Which version of Brave are you using? (e.g., 1.71, 1.73)
- Which OS and version? (e.g., Android 9, Android 14)
- Are you using Brave Release, Beta, or Nightly?
These details are essential for pinpointing the issue and finding a solution.
Also, could you clarify:
- What happens when you click the hamburger menu (three dots) at the bottom right and select Wallet?
- Is this issue happening on all websites or just one?
- Does disabling Shields make any difference?
The more specifics you can provide, the easier it will be to troubleshoot!
We’re investigating this issue! Thank you for reporting.
