Videoes dont work on www.dagbladet.no when adblocking is enabled.
- https://www.dagbladet.no/video/har-han-latt-seg-inspirere/MtTNXK2z
Video is black
Video should be playing
Every time
Brave Version(about:brave):
1.0.91 on android 9. Samsung s9
Yes
@Drakozorro,
Can you check to see if you have Regional Ad-block enabled on your device? You’ll find this in Settings --> Privacy --> Regional Ad-block
It is enabled. Should it be disabled?
Solved! Disabled Brave adblocker and use uBlock origin instead.
system
Closed
5
