Very slow with hardware acceleration enabled
I am having very poor performance in Brave with hardware acceleration enabled on PopOS 22.04.
If i enable hardware acceleration the browser is very laggy, especially when playing a YouTube video… If a video is playing and i try to move the window, it freezes for a good 5 seconds or so before it moves and then moves with lots of lag.
If i disable hardware acceleration the issue goes away…
I am running the latest version of Brave in a flatpak (version 1.38.111).
I have also just tried installing the debian package via the repo’s and have the same issue.
My specs below:
Pop!_OS 22.04
AMD Ryzen 9 3900X
64GB DDR4 RAM
Nvidia RTX 2060 (Driver 510.68.02)
NVMe storage
@llars0689 ,
I leave Hardware Acceleration disabled - for better performance and fewer problems.
Check if driver is up to date.
I have NVIDIA 1660ti with AUTO-SELECT in settings. It is disabled in Brave. Never had a problem.
I have Windows 11, integrated card Intel UHD 630.
