- Task Manage shows Very High Power use when viewing YouTube. This is new.
- Issue appears every time I view YouTube, even with Test Profile.
- Only seems to appear when video in use.
- This effect seems to happen when I am on the YouTube site, whether I’m playing a video or not.
Browser eventually slows to a crawl and then stops functioning.
Version 1.28.106 Chromium: 92.0.4515.159 (Official Build) (64-bit)
](https://brave.com/latest/)
I don’t use Chrome, but I installed it to check the results, got more or less the same issue. I notice a message in Task Manager that says “GPU Video Decode” that fluctuates quite a bit.
Tried using the Chrome experimental speed up recommendations, no noticeable effect. Turned off acceleration, no noticeable effect. Tried test profile, no noticeable effect. Cleared cache, no noticeable effect.
When running YouTube on a much less powerful adjacent PC this issue does not appear. It seems like this is something happening due to a system specific problem.
Here are some basic system specs -
- Operating System - Windows 10 Pro 64-bit
- CPU - Intel Core i7 2600K @ 3.40GHz 132 °F Sandy Bridge 32nm Technology
- RAM - 16.0GB Dual-Channel DDR3 @ 799MHz (8-9-8-24)
- Motherboard - ASUSTeK Computer INC. P8P67 PRO (LGA1155) 85 °F
- Graphics - XB321HK (3840x2160@60Hz)
3071MB NVIDIA GeForce GTX 1080 Ti (EVGA) 92 °F - Storage - 232GB INTEL SSDSC2MH250A2 (SATA (SSD))
931GB Western Digital WDC WD1002FAEX-00Z3A0 (SATA ) 85 °F - Optical Drives - ASUS DRW-24B3LT
- Audio - Creative X-Fi Audio Processor (WDM)
