When using vertical tabs on the left side, the bottom-left corner of the Brave window appears incorrectly rendered. The corner’s bezel appears to be present but is obscured by the vertical tab panel, making the window rounded corner invisible. The bottom-left corner should display the window’s normal rounded bezel without being obscured by the vertical tab panel.
Brave: v1.82.166
macOS: Tahoe 26.0
