Today I began having vertical scroll bar missing from websites. I just noticed it at least. I tried applying an update that was ready to be installed. I didn’t record the version the beta was on before doing this. Sorry. But after restarting Brave Beta - it is still doing this on all pages. When I first open the tab, the bar shows for less than a second and then goes away. The same pages in Brave (not beta) are working fine and the vertical bar is in place as it should be.
- Open a web page, after a fraction of a second, the vertical scroll bar disappears.
The vertical scroll bar should not disappear.
Brave Beta: [Version 1.21.65 Chromium: 88.0.4324.182 (Official Build) beta (64-bit)]
none
