Verification help
Hi all,
i hope that everyone is hale and happy. Not sure if this is the right place to post/ask but ill try anyway.
I have verified my website in my Brave publisher account and it comes up as verified when i look it up on one of the lists of verified publishers.
However, for some reason when i click the small triangle in the address bar to see the tips options it shows that my website is unverified and not set up for tips.
some research has revealed that it seems to be a common problem or technical issue, but i am not sure if this has been resolved.
Any help on tis matter would be massively appreciated.
The website in question is: https://theeccentricseeker.com/
Kind regards,
Hamzah
little wait, all be :sunglasses:
It shows verified for me:
It takes up to 48 hours for your verification status to be updated on the browser side. Perhaps your browser hasn’t updated its verification list yet. You can try restarting your browser to see if that helps trigger a refresh (if it’s been more than 48 hours already).
Thank you, I hope so :pray:
Dear Chriscat,
Thank you for the info and the screenshot! It is massively appreciated.
Kind regards,
Hamzah
