I have almost 50 bucks saved up using Brave Rewards, and the holidays are drawing near. I’m under 18 however, so I’m in a pickle on how to use them. I wouldn’t want to hassle my parents to create an Uphold account and verify their identity just to spend money that’s not theirs. Any tips?
As far as I know that is the only way you can do it, or wait til you turn 18. Just keep piling the BAT in the meantime and once you turn 18 you’ll be buying something very nice. Just be super careful not to reformat your PC or re install brave or you will lose it all.
Perhaps if you explain it to them they may set it up for you and you can tell them you want to buy them a christmas present. They may be very nice about it that way.
