USB webcam does not work on Brave
When using my USB webcam on a site such as Google Meet, turning on camera functions yields a “camera is being used by another app” or “webcam failure” message, even though no such thing is the case (as checked with the Process Explorer software).
  1. Go to Google Meet or https://webcamtests.com/
  2. Allow for camera to be used.
  3. Check error message
For the camera to work without issue.
Version 1.66.118 Chromium: 125.0.6422.147
Camera works on app such as Discord or Zoom and additionally works on Firefox.
Doing a clean install of Brave has not fixed the issue.
Permissions are granted for websites to use the camera.
There is no other camera to choose from in dropdown menus.
asdas
On the Camera settings in W10 it says that Brave hasn’t accessed the camera since May 30th which makes me suspect that Brave is somehow blocking it or can’t access it, but I have no clue how to check for either of those
