A new tab is opened and a URL is typed in, then enter is pressed. The browser seems to start fetching the site, but then the URL disappears and the new tab screen is shown without loading the URL. When the URL is entered a second time, it loads correctly. This does not happen every single time, but at least 50% of the time.
This happens with URLs that are typed in completely, copy and pasted, or auto-completed, as well as clicking on my frequently accessed pages on my new tab default page.
Type URL in and press enter
The URL should load completely the first time.
v1.43.89 (this has been going on for many months though, through many versions)
This has been reported a number of times before (I have to load URLs twice) but no useful fix has been posted. The standard āUpgrade to latest version of Braveā does not fix the problem.
I thought thatās what I was doing posting here. Is there some mysterious, hidden other place to actually submit a bug report? This issue has been reported by multiple users over years and every time the thread is just closed for inactivity after a month. So what can we actually do to try to get this resolved instead of ignored?
@asor Big issue here is itās not being replicated. You did mention from last year, but youāll also see everyone stopped responding to that Topic once they were told to update Brave. So it was assumed fixed at that point.
You talked about crashes, adding Qwant, asking about relaunch, no response when opening new tab with TOR, asking for a Name Window feature, if Bookmarks file is viewable, how to save a webpage in Brave, how to use brave://discards etc. But Iām not seeing you talk anything related to whatās being discussed here.
I always try to look back when people make claims like this as I see what information is provided and try to use it to look for a solution. Iām just not seeing even a single time you discussed this particular issue. Closest related is 'New Private Window in TOR' -- doesn't open, no response at all which unfortunately got missed.
If so, then how about if you Create a new profile and go to use it?
Brave has rolled out an update since you originally posted, can you verify youāre using 1.43.93?
Just so you know, Iām on Windows 10 Pro and using most recent version. Iāve tried opening over 100 tabs and typing in URL and hitting enter. It just goes straight to the site each time. Iāve not yet had any issue where the URL disappears or the new tab screen is shown without loading.
I tried this on Android, iPhone, and Windows 10 Pro. None of them had the issue. If it is something that canāt be replicated by others, then itās not really something we can create a Github on and is challenging to try to figure out. What it suggests is possibly something within your device. Whether it be drivers, keyboard, browser settings, extensions, antivirus, or whatever. Itās a lot of little things to work through.
Iāll tag @Mattches just to see if he can test on his devices and if it replicates. Or if he might have an idea what would be causing this issue for you.
I understand you have to say āhave you installed the latest updateā but this issue has been going on for a number of users for years now. Installing the latest update does not fix it.
Obviously not everyone has this issue, which is often the case with bugs. So saying āI donāt have this issue and canāt replicate itā doesnāt change anything. I still have the issue, and clearly others do as well. I understand that makes it hard to troubleshoot and track down. But looking at the various posts, this has been going on for years with multiple people. Just closing out the issue because everyone gets frustrated with the same old āinstall the latest updateā advice does not actually fix the problem.
I understand you are trying to help here, and Iām not trying to be a jerk. But it is frustrating for those of us that this problem seems to be ignored every time anyone posts about it. I canāt find any record of anyone taking it seriously and actually trying to track down and address the problem.
As I said in the post, we had some Users who mentioned it last year but then they stopped responding. I havenāt seen anything recently. If you have, can you link to it?
Not true. Lots of things get fixed in updates. For example, recent update fixed crashes people were having for a variety of reasons. Weāve also had people who have had random little bugs get fixed in updates. (opposite too, such as where new updates were causing issues with Sync)
Saying that means that itās not easy to find. When Iāve talked to people at Brave, they advised me not to create Github tickets unless something affects a large number or Users (which your situation isnāt) or unless it can be replicated (which yours isnāt).
Nobody closed out the issue. First thing I want you to realize is in some that did close, was because nobody responded for 30+ days. If it goes unnoticed and Users donāt keep it alive, then the system closes tickets and it moves on.
That isnāt just the solution. Itās a question of whether the issue persists. Itās kind of important to know as it can help narrow things down a bit. And if youāre not on the most recent version of Brave, then makes it even harder to help because they arenāt going to be working on changing code in outdated versions. So itās incredibily important to ask this and make sure Users ARE in fact using the latest update and can say whether the problem continues or was fixed.
I know, neither of us are. Donāt think anything being said is insulting to each other. Youāre expressing you have a problem and Iām expressing what can or canāt be done, how difficult it is to resolve, and then just asked for some basic troubleshooting steps and to verify some information. Then tagged in someone from Brave who focuses on Browser Support.
Yep, so something I missed. This is part of the reason why I ask questions, so can see. I think that was during a time they pulled SaltyBanana off of Brave Community to work on a few projects, hence the delays in responding to you. And unfortunately nobody, myself included, saw it or got involved. Of course, part of the issue there is it seems like everyone stopped communicating and it auto closed.
I do jump on a lot and have been for a while, but I tend to respond more to recent and updated posts/topics, the ones that appear under Latest and donāt always go back in time too much. It kind of gets assumed issues arenāt happening anymore or person gives up if it goes a while without any responses.
I donāt think Iāve seen other posts/topics from others since, but Iāll try to research a bit more. Itās currently the weekend, so likely wonāt have anyone from Brave poking their head in until after Monday. At that point, will see if maybe @Mattches might have any ideas what can be causing problemsā¦assuming we donāt manage to think of something ourselves over the weekend.
Also going to tag @Chocoholic to see if they are aware of any tips or tricks. They typically keep track of a lot of issues and how to solve them. Maybe weāll get lucky.
That does happen, and one doesnāt wish to keep barking when there is no response.
One (e.g., the Brave user) is also not in a position to determine what resources Brave (the company) has to address what is probably a very large number of issues. (Another reason to give up.)
That said, I hope Brave wonāt give up, as the issue is one that must have a cause that hopefully can be found. And it is very persistent (i.e., in no way a rare occurrence).
Itās a strange phenomenon: dropping a URL into the URL line, seeing it there, then seeing it disappear, then repeating the action and finding (without exception) that the second try always works.
Yeah, guess main thing on that when I say they give up, is then the topic doesnāt end up within Latest and eventually it gets drowned out in the bunch of nonsense posts. (like all these people talking about unsupported regions even though official notices already have been made).
Not sure if youāve ever looked, but https://community.brave.app/about has a small portion that shows how many posts, topics, etc are made in a given day, week, month, and all time.
Topics doesnāt seem too bad in theory, but the problem is nearly 400 posts (comments) and many of those are tagging people and/or are off-topic. Then thereās all the actual support tickets submitted. Between it all, itās easy to miss something or forget about something you were working on with people.
In that aspect, itās very important to keep a topic alive as long as an issue persists. (especially if you can do it when you see someone active.)
Should say, also makes it harder for those at Brave as they also have to try to balance everything and find solutions. Of course, more critical issues and easily diagnosed problems tend to be handled first. More complex things like this get worked on in between, though challenging if canāt replicate.
If you didnāt notice it in the May 2021 thread, user āpoliticusā (https://community.brave.app/u/politicus) reported what seemed to be the identical issue.
Thanks also for the stats link. (They left you out. āOur Moderatorsā.)
