Uphold Wallet “Connection problems”
Very Simlar to the other post if not the same. Wallet says: Connection problems
I Have cleared catch i have deleted app off uphold so i could reestablish connection. i have uninstalled and download now Brave browser.
It has never connected. Uphold says it has not Brave creator page has not
Im verified with uphold.
Ive searched here and it seems that none have an answer. They all have posted about the issue and by the end of the chat no solution was every mentioned but they all have seemed to magically had there problem solved. Hence the reason im posting.
When i go into the Developer Tools to see if theres any errors there are none
Experiencing this as well.
Edit: Resolved itself after some time, logged in and it was just connected.
