Apparently my vBAT will be lost end of this month unless I get Uphold. Not that I can find anywhere to tell me if I’ve got any vBAT, but that’s another issue. Uphold is ALWAYS closed for maintenance. Is that correct or is something else going on?
Briefly describe your issue:
1.59.117 Chromium: 118.0.5993.70 (Official Build) (64-bit)
Is your Brave Rewards Profile currently verified? (yes/no)
Don’t know, can’t see how to find out.
No
Are you using a VPN? (yes/no)
Yes. Proton
Yes, NZ
Don’t know, don’t know how to find out.
Have you fully completed Uphold’s CDD requirements?
Can’t get to Uphold because their site is always closed for maintenance
