Brave update doesnt work
ERROR An error occurred while checking for updates: Update check failed to start (error code 4: 0X80070005 – system level).
Brave 1.91.175 (Official Build) (64-bit)
Chromium: 149.0.7827.155
This can happen sometimes. Can you try re-downloading the installer from our website and running it? This will fetch and apply the latest updates (note that it will not overwrite any data, it will just apply any new updates).
Please let me know if this does the trick.
It worked!!!
Thank you
The help page said I would have to save all info, uninstall brave and start over
You saved me a lot of grief
Thank you
