In the latest Android build, I’m unable to add presearch.com as a search option
- Visit presearch.com
- Do a search
- Go to Settings->Search engines->Standard tab
Able to add presearch.com as a search option
1.39.115
Mobile Device details
Onplus 7 running Oxygen OS 11 based on Android 11
Hi
You can add a custom search engine in desktops; I don’t think you can add one in Android.
Hello!
Actually I was able to add it when it was presearch.org. Due to a switch to mainnet the URL is changed to .com. The old URL no longer works
Hi
I managed to add it to Brave Nightly latest Android 11.
How? Did it show up in recently used?
Hi
I just followed what the_reckoner explained in his original post.
- I opened in the URL, presearch.com
- I clicked on the 3 vertical dots, opened “Settings”, then “search engines”
- You will find presearch.com in either standard tab and private tab, under recent visits.
Doesn’t work for me, but I’m on android 9. Ive tried https://engine.presearch.org/ and presearch.com
