Vertical Tabs has a thicker gray bar at the bottom. Seems like the vertical tab pane is not extending all the way to the bottom of the screen. When expanded on hover, you can see a sliver of content underneath the pane at the bottom.
Viewed on Mac.
Version 1.78.97 Chromium: 136.0.7103.93
