I am unable to connect my brave wallet to my uphold which was previously connected to it and got disconnected after i changed the password.
my uphold was connected to anther wallet ,to which i was successfully able to connect to it.
i have seen many topics regarding this issue but none of that seems to be resolving problem related to this and i get this error message on my reward page - “Uh oh! The Brave Rewards server is not responding. We will fix this as soon as possible”.
additionally , i am not using any VPN or extensions
Can you try reconnect your Uphold account via BAT triangle icon at URL bar?
Yes, but it loads up my uphold account instead of connecting it and when I exit that it still shows the error message in reward page as in the image above.
what should i do now?
Just to make sure, you disconnect and reconnect your Uphold account right?
@eljuno
I was never able to fix the same issue
Same here - how do you get around this issue?
Same problem here, since a long time, I don’t have any VPN turned ON, I tried to reconnect my Uphold, nothing happened, cleared my cache too
Yes , I just changed my uphold account’s password which resulted in disconnecting the brave wallet and then when I tried connect it , it started showing this message.
how am i suppose to ?
Yes - on what platform?
is there nothing to fix this?
@eljuno please fix this or at least respond!!!
@Zavi apologies for late response. I’m AFK for the past days. Can you get in touch with Jimmy? ![]()
My workaround mentioned above is works for most cases. Since it happened to me too.
How can i contact him?
@eljuno how can i contact him ?
Hi @Zavi can you DM me?
