Udemy video problems on a Mac
- Udemy video - when I move the pointer over the video the video disappears.
- Udemy video - the video control panel (control playback) is not visible.
The ability to play Udemy videos normally, with full control and visibility.
Version 1.21.77 Chromium: 89.0.4389.90 (Official Build) (x86_64)
Does it work in a private window mode? @whatever99
It sure does. The udemy video plays fine in a private window. It must be shy.
Re-try in normal mode, but maybe disable your extensions (just in case), see if it helps.
This was the offending extension! tsk tsk. I will need to find something more suitable.
Dark Web - Dark Theme for Chrome
Simple button turns on dark mode for all webpages. Classic design of Dark Theme changes web to black color
Great to see it working now
