can two different creators account bind same uphold account
Yes you can connect 2 or more creators account to 1 uphold account
@chriscat is it okay
Connecting the same Uphold account to more than one Brave Rewards creator account is not permitted. Instead, you should add all your sites and so forth to the same one Brave Rewards creator account.
