twitter and twitch just not working for the whole day
Both work just fine on my end. Delete your browsing data and try again.
You can delete your browsing data at brave://settings/clearBrowserData.
already tried that did nothing
All right, try disabling Brave Shields temporarily. Do you see any error message when you open both websites?
didnt work for both for twitch it says network problem but i have it open on chrome and its working. For Twitter it just says something went wrong i cant even sign in since i cleared the data
Clearing browsing data doesn’t break websites’ functionality, that’s for sure.
Since disabling Brave Shields and clearing browsing data didn’t work out, you should test with a fresh user profile.
making a new profile seems to work is there anyway to transfer all of my current stuff to the new profile
You can export your current profile’s bookmarks.
- Go to
brave://bookmarks/. - Click on the 3 dots.
Export bookmarks.
Follow the first two steps but click on Import bookmarks in order to import them in your new user profile.
i seem to have found the solution to the problem. Apparently i had ad block plus from my old chrome browser and it went to brave. I turned it off and everything seems to be working now. Thanks for all the help have a good one
Good you figured out the issue, happy browsing
Great support @Rethanis
