Trying to go into Creator login and it fails to load
I get into brave
Click on “Content Creators”
Page fails to load and says Application Error
On page itself it shows this:
Application error
An error occurred in the application and your page could not be served. If you are the application owner, check your logs for details. You can do this from the Heroku CLI with the command
heroku logs --tail
@Kaszixx are you still unable to login or still see the message?
