Tried to transfer funds from Brave wallet, stuck in limbo, missing funds
Hoping to get help from Brave support.
I tried to transfer eth-etherium mainnet from my Brave wallet and the transaction shows “submitted” and the funds are gone, but they haven’t reached the recipient. It’s been 5 hours now and the transaction link says “This transaction was forwarded to Flashbots Protect RPC but was not mined and has expired.” and “Transaction Hash not found on Ethereum”.
I double-checked the recipient address and it is correct.
Where the heck is my money and how to I get it back?
Transaction hash: 0xb16d751ff227966f3a862d1b3f6156f308cdf9e1fc300b8e01cf1187573f4751
Hello! This means the transaction did not go through. You’ll need to retry it. Could you provide your address as well?
This is mine: 0x4dF4fF44417E24F0DFc69B3FB9326Ac7c4fEd614
The 0.1 ETH was sent out around 5 hours ago to 0xD431F9450d4Cea1687c020055799828CD9542adb. You can see the transaction below.
I got a Problem like this, on transaction since February isnt working and i cannot stop it, the problem since then i cannot use my wallet at all because all new transaction dont work anymore, this is the transaction since i cannot use my wallet anymore:
@Manuel5 Please reset your transaction and nonce information at brave://settings/web3. You should be able to retry the transaction after resetting the txn history. Thanks!
