Totally new newbee question - what info do you need from me in order for me to receive rewards?
Hi
Totally new Brave-user newbee question - what info do you need from me in order for me to receive rewards?
Thanks
Kind regards
Mike
Hi
@mibdfk
What device do you use for Brave Browser?
Does your device accept ads notifications? Check if you have received a notification for this message.
Is Brave available in your country? https://brave.com/transparency/
Are ads available in your region? https://sampson.codes/brave/ads/my_region/
Is Uphold available in your country?
What is your default opening page in Brave? It should look as below.
default
Hi
Thanks for the reply.
Device: Computer
Ad notifications accepted: No idea. I see the ads on Brave.
I am using Brave no probs, so I am not sure I understand the Q.
Ads available in my region: Well… I click the ads that appear on the starting page… so yes, I guess.
UPHOLD… what is that?
Default opening page is the one you point to.
Thanks.
PS: My country is indeed a supported ad country.
@mibdfk
Open page and test for notifications https://www.bennish.net/web-notifications.html
  1. Click on authorise
  2. Click on Show
@mibdfk
In addition to Uphold, there is another crypto wallet called Gemini
To check if supported in your country follow the steps;
  1. Click on the rewards icon (triangle at top of page)
  2. Click on unverified
  3. Click on Gemini
  4. Go to bottom of page and click sign up here
For Uphold check at their site. To sign up for Uphold wallet, you need a minimum of 2 BATs in your balance
