Token grant claiming issue
Frequently I get a notification in Brave browser indicating to claim the grants. When I click on that, it will spin for sometime and finally provides 0 BAT. This keeps happening occasionally. So far, it’s been months that this issue is persisting. Even my friend’s mobile too has same issue. Both are Android.
  1. If I close my brave browser completely (including tabs), it may be reproduced.
  2. Another scenario can be try opening brave browser after a day or reboot phone.
It should provide appropriate BAT instead of 0 BAT every time.
version: 76.0.3809.132 (official build) (32-bit)
Mobile Device details
OS: Android 9; GM 1901.
Another Mobile: Android 7.0; SM-J327T Build.
This is a known bug at the moment I’m afraid. We are working on a fix. Apologies for the inconvenience. Make sure you are on the very latest build of Brave on Android as well.
I am using V1.3.2 for mobile (which is the latest version in Play store). Still facing the same issue.
