"There was a problem processing your contribution" [ ERROR ]
There was a problem processing your contribution.
Hi I have error encounter with brave browser.
I click the small triangle but its show “There was a problem processing your contribution.”. I believe there are many issue I see in the forum but seems like you can help me on this.
The brave browser version I use is as follows:-
Brave is up to date
Version 0.68.132 Chromium: 76.0.3809.132 (Official Build) (64-bit)
I wait your kind reply for this.
Thank you
Vincent
There should be a small check mark that you can use to close the dialog box that shows up. You should be able to use your wallet normally after that.
Hi Asad,
Thank you for your reply.
I did not see any. I attach as follows:-
Thank you and wait you kind reply.
Try clicking the small “X” in the upper right corner, above “there was a problem processing your contribution”
