- Attempt to switch to a tab that was already open
- Tab has no content displayed, just a blank white color
- Reload the tab
- The blank white turns into gray instead (I have dark mode on) with clickable links
The webpage should display content normally and everything on it should be visible
Brave is up to date
Version 1.73.104 Chromium: 131.0.6778.204 (Official Build) (64-bit)
In the blank gray space, links can be moused over (cursor changes to a hand/finger, indicating there’s a link that can be clicked on) but clicking on the link loads that link’s page with the same result (another blank gray color with clickable links).
Reloading does not help, but visiting another webpage, letting it load completely, then returning to the previous webpage causes the page to load correctly.
