The pages redirected by the new update are opened in a window and we can change the pages while in that window. The bottom place where I can change pages is not working. To change, I have to go to the tabs, go to the window and select the page I want. When will this fix or how can I fix it
Also having this problem, Im using a huawei phone on Android 11 OS. Hope this gets seen by the devs
Hey @Cavus,
If I’m correct, this a feature called tab groups. Luckily for you, you can disable it by going to Settings → Appearance → Enable Tab Groups.
The feature should be on by default, so if you want to turn it off, that should do it.
THANK U SOOO MUCH. It works:heart:
but I didnt enable groups. I open bottom toolbar
You’re very welcome. Have a good day, Cavus.
