Tabs from other devices not showing anything. Completely blank page
SyncedTabs function not working on my end as I cannot used the syncedTabs to view other open tabs on other devices on my sync chain.
Steps to Reproduce
Said issue has appeared for all devices and I am not able to view nor access the “Tabs from other devices” upon going through Brave’s History tab. Two days ago I was able to use the function, today I am not. Not sure if possible to replicate issue as it just appeared out of nowhere.
Issue has been occurring for every instance of Brave running on devices that are able to access the “Tabs from other devices” page."
Brave Version:
v.1.29.81 (64 Bit on all Win10 Devices)
3 Devices: Desktop (Win10), Android-Samsung, Laptop (Win10).
I have deleted and reinstalled Brave multiple times, deleted said sync chain and started a new one, and have switched out devices.
The only extensions that I have installed think may be causing are the following: uBlock Origin, ClearURLs, Decentraleyes, PrivacyBadger.
PhotoReference:
same, but with win10 + ios15.1! extensions: adblock for youtube, dark reader, google translate, bitwarden, easy auto refresh, unpaywal, google docs dark mode
Have you guys figured out a solution? I had broken whole sync, now after i created new sync chain “sending tab to other devices” work but passwords, history and tab synchro. still don’t work :frowning:
We are currently having some Sync server issues that the team is working through at this time. @jezevec93 all data types should sync as expected once the issue is resolved.
Thank you.
Tbh, sync have not worked for me ever… Thats why i tried to recreate synch chain few times but still it isn’t working (using brave for a few months already)
One workaround that IS working for me is to create a tab group and turn on the Save Group option - that is syncing well between Brave on my Mac and Windows computers.
I, too, have noticed this problem, between multiple Win11 machines, and Android phone, and a MacOS system. It’s very recent for me (past several weeks) and I noticed it primarily because I rely so heavily on this helpful function.
Sadly, I have no solution to offer, but I look forward to it’s reappearance.
Any updates on it?
I just got a new mac and trying to sync it with my windows pc but the tabs from other devices is blank. If there any solution to this lmk
Same issue. v 1.73.105
I have sync with 3 android devices, which all have several tabs open, so the desktop brave should show them but it isn’t.
My main W10 PC cannot turn on for some Bios Issues.
I’m on the backup hoping to Sync everything.. Chrome did it perfectly.
Brave don’t see it anymore the main … so I cannot get my 12 Windows and 140 tabs… As I left it before the crash .
W H Y ? ? ?
( I thrusted Brave more then Chrome, did I do a mistake ? )
