Tab hover cards transparent hard to read
when hovering over tabs to see usage, or when installing extensions, the tabs that pop up are too transparent and hard to read
  1. launch the browser, open a tab, hover
  2. open another tab.. repeat
    3.try installing or modifying an extension
  3. same result in hover with preview
tab too transparent
issue only on new and clean install of Brave Nightly 1.182.114. This does NOT happen on my Brave or Brave Beta
under legit and updated Windows 11 Pro.
all drivers updated
standard graphic driver install
have tried different color palates, searching for and not finding a setting in //flags, not finding anything in settings, tried launching with --no-gpu and/or --disable-software-rasterizer with no avail. Reboot browser, reboot machine.
cannot produce in Brave or Brave Beta
Persistent in Brave Nightly
Only flag changed was for ANGLE from default to D3D11with12. Issue happening before that flag was changed. (side note, using d3d9 will brick Beta and Nightly)
Picture attached
