Hi. I’m very new to using Brave but I like the concept. However, something that would prevent me from being able to use it is the problem I’m having with tabs and new windows. I often need to pull a tab into a NEW window (not an existing one). On Firefox and other browsers, I can simply drag a tab down and it will automatically pop into a new window for me. How can I do this with Brave?
The only way I’ve been able to do so on Brave so far is when I pull a tab down, it does open a new window but that new window is well below the first window. When I try to move it back to the top, the tab automatically rejoins the first window. I do not want this. I very often have different things going on in different windows and each window may have more than one tab. How can I fix this? It’s a deal breaker for me if I cannot.
Thank you.
NOTE: Any “one-liner” or topics requesting support or reporting bugs that do not make an effort to include as much of this information as possible will not be responded to. Repeatedly posting as such is grounds for banning._
