Tab discard problem
Description of the issue: Tabs discard is not optional. There is no option in the settings. Or it is not findable.
  1. Open tab with time sensitive functions: web/live chat, calendar, music, etc.
  2. Go to another tab (or another application) for a while
  3. Tab with running events/chats/timers (anything ongoing) stops working.
Expected result: An option in the settings for things to continue functioning - to be able to set a tab to never hibernate/discard permanently
Brave Version( check About Brave): v1.59.124 (Oct 25, 2023)
Additional Information: This issue has been created many many times before, but no one from the support team has responded properly. I found many topics. But I couldn’t find even one permanent solution.
For reasons like this, I deleted Brave before. (google translate mic does not work, tabs discard automatically, web pages sometimes have problems, etc.) For some reason, I abandoned Chome and went back to using Brave. But as soon as it arrived, Brave started to be annoying again.
I think the Brave browser is completely chrome based. Although there is no such feature in Chrome, I cannot understand why you felt the need to add such a dysfunctional and annoying feature.
This option should be made optional in the settings section. There shouldn’t be a need for a plugin etc. to do this. These are my opinions. If there is no solution available, please take a developmental approach in the form of “we will work on it”. Alternative solutions do not improve the browser. We want to use a nice browser. This should be a very easy problem to solve.
Thank you for your interest
If you used the search function, you would have found the Memory Saver settings. Also, Memory saver is disabled by default, so I don’t know why you are saying it not optional.
You can exclude sites in brave://settings/system… and you can adjust more things by enabling flags which enable more settings in the System section as well.
Also, Chromium doesn’t freeze (when you collapse tab groups) tabs that have the Notification permission on, so you can add the domain like if they used notifications in brave://settings/content/notifications and control it that way. I don’t know if notification permission matters for the discarding, only the frozen state, but since there is an exclusion place to add sites in settings, then use that.
Browser putting background tabs in lower priority, is not the same as discarding, backgrounding processes is a normal thing to avoid resources that shouldn’t happen, like when you watch a video muted and you go to another tab, the video might stop because it is useless to play a video that is muted in the background.
Tabs can also know when you are focusing or not in them, like when you use Tiktok or Facebook and you try to switch tabs, well, videos will get stopped, that could easily be done (and removed) by JavaScript, so how do you know the websites you are talking about doesn’t have something similar?
To make sure you are correct about tabs getting discarded go to brave://discards, don’t just say tabs are getting discarded, test properly, don’t make assumptions.
Like the mic thing and ‘websites don’t work properly sometimes’, if it is an adblocker issue, you can easily report it and get it fixed, even from the browser’s menu Alt+e and help → report broken site.
About the Mic, you can easily find this post
and understand the issue, it is not Brave not wanting to do it, it is google’s non-standard implementations which still are a problem today. even some people in the Github issue said it didn’t work and other said, it works, and Microsoft has power and money Brave doesn’t have.
I am not going to also discuss the whole “using Brave but wanting to give Google my voice data” but it doesn’t make much sense as well. But people can do whatever they want, they can’t just blame Google for Brave not having money to throw at Speech APIs and stuff only few users would use when there are more things to be done with the Browser.
