joining a desktop sync chain from android is impossible
open brave for android, go to settings>sync, try to find an option to scan a QR code and give up after not finding it
any time you like
1.30.86 Android
Desktop
did you try copy paste the sync code instead of scanning…and please make sure that sync everything is turned on
@Dex welcome to Community
Thanks for posting, apologies for the wait time.
Are you attempting to sync between your android device and desktop?
