Still problem with showing youtube comments
I’m on Manjaro v.5.2.21-rt13 (LXQt v.0.14.1) and using Brave version 1.0.1 Chromium: 78.0.3904.108 (Official Build) unknown (64-bit)
Got Brave from AUR
Brave-bin 1:1.0.1-2
I have tried every tip like “reset brave to default” “disable HW acceleration”.
Had this problem with the previous version of Brave as well v.10.0.1.
Otherwise i’m super happy with Brave.
Keep up the good work!
Having the same issue on Windows 10. Had no problems on Windows 7. Between this and sync deleting months of bookmarks, I’m starting to want to throw in the towel on Brave
@litepalle @kengle Try logging out of youtube, then just log back in (this will reset the yt cookie). and should resolve this
Thx for the reply.
I’m never logged in to youtube. Tried deleting all cookies but still nothing.
Does private mode make a difference?
Nope :frowning: I’m afraid not.
Logging out and clearing cookies did not help
Private mode makes no difference
Okay, try a new profile. (Just download the Brave Beta) and re-test (with no extensions) in that profile.
