StartPage Search Engine Not Working
Last day or two StartPage search Engine no longer showing options such as News, Images etc. It only shows 3 options, and even the settings option is missing. Startpage is working on Vivaldi and Firefox.
I’m including and example in case you’re not sure what I mean. Could someone please help me with this.
Thank You
~ Jo
Removed SP, reenabled it, launch browser, search and still same issue.
Well I expect to have the options there like all search pages and engines work SHould have a header section.
Version 1.64.122 Chromium: 123.0.6312.122 (Official Build) (64-bit)
Same issue… And Brave seems to think its not downloaded and just logged me out while trying to reply to this report. What is going on Brave?
$20 says they say reset all your settings. I’m not doing that bunk anymore. I never have to reset anything with my other 3 browsers I also use daily.
Well I did clear my search history… Startpage STAYED BLANK afterwards… But suddenly its working again after an hour of going through every page and relogging back in. Not having to log into Startpage at all, seems odd that it wouldn’t be working. STILL WANNA KNOW WHY BRAVE IS ACTING ODD. I even ran a Malware scan and found nothing. I don’t get it.
@Sarys @MeesoeDontask You should try some basic troubleshooting steps. And no, resetting settings isn’t one of them. In terms of saying it’s not working with Brave, that’s wrong. For example:
Majority of time issues experienced are because of (1) extensions (2) cookies (3) settings.
What you should be checking are:
  1. Turn off Shields
  2. Open in private window.
  3. Create a new profile. (I’m assuming you’re on desktop). It’s Hamburger Menu imageMore ToolsAdd new profile (make sure you don’t add extensions or change settings to this)
@Sarys,
As @Saoiray states, I would test this behavior in another browser profile and/or in a Private (or guest) window to see if the behavior stays. Testing on Windows and macOS, Startpage seems to work normally for me:
I’ve also that problem today.
