standaloneenterprise.64.msi is overriding my Brave search engine
Everytime is try to use the Brave search engine the Brave search is taken over by Googlechromestandaloneenterprise.64.msi takes over and does a yahoo search. This is very frustrating can anyone tell me how to get permanently rid of Googlechromestandaloneenterprise.64.msi
g, please:**
  1. Search the forum to see if anyone else has already posted or resolved the same issue you’re having.
  2. Ensure that you’re posting in the appropriate category — please use the appropriate category when posting to ensure that whoever assist you has a clear idea of what product or platform you are using.
  3. Fill out the template that appears in your editor when posting as it contains all the boiler-plate information surrounding your issue. It will help the Support team members and other Community members to efficiently assess and resolve your issue. NOTE: “Uncategorized” posts do not have a template, so please ensure you’re posting to the right category as mentioned above.
  4. Tag your post appropriately – use tags to help track and organize threads on this forum.
  5. Observe and adhere to our code of conduct
This sounds a lot like an extension hijacking your search or potential malware on your system. If you have extensions installed in the browser, please try disabling them and test again. If you don’t (or if the issue persists after this) I’d recommend running a scan with whatever AV software you have on your system to ensure it’s not malware.
