Description of the issue: The links in the site don’t function properly with the shields on and tracker & ads protection. The “Sign-in” link on the site does not open and the same error persists on the next page when you try to sign-up after putting in email, mobile and OTP required(next page).
Exact URL of the website in question: https://upstox.com/open-demat-account/
Did the issue present with default Shields settings? (yes/no) Yes
Does the site function as expected when Shields are turned off? Yes
Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration. (yes/no): The moment I allow the trackers & ads, the site starts to work fine.
Does the site work as expected when using Chrome? Not used chrome but it works fine on Microsoft Edge
Brave version (check About Brave): Version 1.25.68 Chromium: 91.0.4472.77 (Official Build) (64-bit)
