I noticed that some shortcuts do not match the help page for shortcuts.
Examples:
Turn full-screen mode on or off:
⌘ + Ctrl + f
Does not work for me. Does nothing. I have to press fn + f
Make everything on the page bigger:
⌘ and +
Does not work for me. Does nothing. I have to press ⌘ and Shift +
(But “Make everything on the page smaller” with ⌘ and - functions.)
I use these shortcuts very often. So it was a surprise for me when they didn’t work anymore. I had to try several other keys until I found out that the shortcut had changed.
I do not believe that this change is intended, so maybe it has to do with an update of Brave or macOS?
I am using:
Version 1.35.104 Chromium: 98.0.4758.109 (Offizieller Build) (x86_64)
and macOS Monterey, Version 12.2.1.
